Date/Time: Wed, 04 Nov 2026 14:21:29 +0000
Migrating from TT to CQG
View Count: 1022
[2021-02-18 15:23:17]
mnill - Posts: 37
Some questions regarding switching from TT to CQG:
1. Does it appear the TT issue will be continuing for an extended period of time with AMP and thus it is recommended to switch from TT to CQG?
2. Does it take 7-14 days for the switch to be completed or is it completed in one day?
[2021-02-18 15:31:06]
User548030 - Posts: 25
I'm also in the same situation, I thought I would add relevant questions here instead of starting a new thread.
Can we still use Denali Data Feed but with CQG order routing?
[2021-02-18 15:35:54]
Regarding the first post, could you please ask your broker AMP these questions.
Yes of course and that is highly recommended. Refer to:
Denali Exchange Data Feed: Introduction
[2021-02-18 16:17:36]
I have filled the form to switch to CQG routing through AMP. However they don't have the option to select Denali with CQG. So I have selected NO Data through AMP and only CQG routing. I will enable Denali through my sierra chart account. Is this correct?
[2021-02-18 17:14:07]
User548030:
You have your Denali Exchange Data Feed setup through AMP. Therefore, there is no reason to change this. They should just switch your trading service from the Sierra Chart Order Routing to CQG and leave the rest as it is.
[2021-02-18 17:30:01]
Thank you, they have update the form and I think everything is working now.
I'm just wondering if there is a way to verify if I'm getting Denali or CQG data through Sierra.
[2021-02-18 17:40:31]
Will Server Side OCO be supported with CQG Web API order routing?
[2021-02-18 19:03:32]
Look for the [M] at the end of the symbol name in the Chart Header. If the [M] is there, then you are getting the data from Denali. Refer to the information towards the bottom of this section:
Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services
Right now, this change is just moving to the standard CQG trading service. Therefore, refer to the information here for what is available:
CQG Trading Platform Service: What is Included
