Date/Time: Wed, 15 May 2024 09:01:31 +0000
Only loading one day when viewing Market Profile Evening Session
View Count: 492
[2021-02-10 16:57:55] |
oliver.sparing - Posts: 4 |
I currently have the problem that the software only loads one day of data if I set my market profile chart to evening session, although in the chart sessions I have set it up to load 40 days. If I switch to intraday session times, the 40 days are loaded and displayed correctly. Also, in all other candlestick charts I have opened everything works fine in evening as well as intraday session. Is there a certain parameter within the market profile settings I have to change to make this work?
Screenshot_19.png / V - Attached On 2021-02-10 16:56:59 UTC - Size: 177.33 KB - 156 views |
[2021-02-10 17:38:45] |
John - SC Support - Posts: 31627 |
You can't have your session times overlap like you do. Refer to the information here: Chart Session Times: Use Evening Session (optional) (Chart >> Chart Settings >> Session Times) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-02-11 04:48:34] |
The overlapping session times is not the issue. If you remove the TPO profile chart study from the chart, you should have up to 40 days available in the chart unless the data file does not contain the data.
