Date/Time: Thu, 16 May 2024 12:42:54 +0000
Need to know: How to scroll vertical without price bar?
View Count: 418
[2021-02-10 09:17:35] |
Matt NL - Posts: 91 |
Hi guys So I have 3 charts (different time periods) next to each other. Only the one on the right has the price scale on the vertical axis (right). I can use this with my mouse to change the vertical zoom, then move the charts up and down etc. But how can I do this on the other 2 charts which have the price scale disabled? Thanks Matt |
[2021-02-10 15:26:20] |
John - SC Support - Posts: 31666 |
You would have to use the Hand tool and make sure you have the following option enabled: Chart Drawing Tools: Support Vertical Scaling/Movement With Hand Tool (Global Settings >> Tool Settings >> General >> Tool Options) Another option would be to link the charts to have the same Vertical Scaling. Refer to the following: Chart Settings: Chart Linking (Chart >> Chart Settings >> Linking menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-02-10 16:49:35] |
Great, thanks!
