Date/Time: Sun, 05 May 2024 08:14:20 +0000
Problem Datafeed for new members
View Count: 387
[2021-02-09 15:51:14] |
User921285 - Posts: 1 |
Hello Sierra Chart Support I am new to SC and I have the following problem. I bought SC 1 month ago. As far as I understand, I have to buy a datafeed. They have recommended to use AMP. I opened an account there and it is also varified. And now I am stuck. What do I need to do? Do I need to capitalize the account to get the datafeed? As I said, I am new to SC and ES.In the first weeks it would be ok for me to have lagged data to get to know the environment. What should I do in the next step? Regards, Karl Ritsert |
[2021-02-09 16:29:27] |
If you are fine with delayed data for now, then just simply use the Delayed Exchange Data Feed as documented here: Delayed Exchange Data Feed If you are interested in EUREX data, we will have delayed EUREX data out in about two weeks or sooner. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-02-09 16:29:36
