Date/Time: Tue, 14 May 2024 12:43:50 +0000
Need help on data requirements
View Count: 382
[2021-02-08 16:10:21] |
User716258 - Posts: 7 |
Hi there... I trade a large basket of instruments in CME, Forex, and Crypto. 1. I need real-time CME, forex, and crypto quotes. From what I've read it seems I would want to go with the Denali feed, and then open another instance for my SC feed and the SC feed would cover both forex and crypto. Is this the best way? FYI, I'm a swing trader (3-10 days), not necessarily a day trader. |
[2021-02-08 16:30:45] |
John - SC Support - Posts: 31602 |
You will need the Denali Exchange Data Feed for the CME Data. Refer to the information here: Denali Exchange Data Feed The FOREX and Crypto data is included with your Sierra Chart package, so there is nothing else you need to purchase for this data. If you are just using Sierra Chart for charting, then you only need a single installation, as you can get charts for all of the data at the same time. If you are using Sierra Chart for trading, then you will probably need to have different installations in order to setup one for your Futures trading and another for your FOREX/Crypto trading. Refer to the information here: Using Multiple Data and Trading Services at the Same Time For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
