Date/Time: Sun, 12 May 2024 23:42:03 +0000
es halt trading time and maintenance time
View Count: 431
[2021-02-06 16:41:52] |
User876085 - Posts: 14 |
Hello Am looking for a way in sierra Charts to draw a vertical line at the halt trading period and the maintenance period each day on the ES. If possible would like the line to be visible on the chart as those time periods approach. Here is a snip from the CME: CT with a trading halt from 3:15p.m. - 3:30p.m. CT; Daily Maintenance period Monday - Thursday 4:00p.m. - 5:00p.m Thanks Irv Olsen |
[2021-02-06 17:19:17] |
Ackin - Posts: 1865 |
Try: Time Range Highlight - Transparent Time Range Highlight - Transparent or Time Line Time Line |
[2021-02-06 17:22:22] |
Adding/Modifying Chart Studies 1) Open or go to an already opened chart for which you want to add studies to, or modify the studies of. 2) Select Analysis >> Studies on the menu or press the F6 key on your keyboard to display the Chart Studies window. 3) To Add a study, select a study in the Studies Available list box (see image to the right) and then press the Add button. Any number studies can be added to a chart and even the same study can be added more than once to the chart. For example, you can add 2 Moving Averages to the chart, each with a different Length input. Chart Studies: Adding/Modifying Chart Studies Date Time Of Last Edit: 2021-02-06 17:23:01
[2021-02-08 06:55:41] |
Refer to the Vertical Grid: Chart Menu: Vertical Grid (Chart menu) You can have a vertical line start at the trading day. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
