Date/Time: Sun, 19 May 2024 00:04:19 +0000
CL data seems delayed by 10 minutes
View Count: 477
[2021-02-03 15:57:55] |
Anapurna - Posts: 10 |
CL data seems delayed by 10 minutes. I thought I had set up real time data for CL. I checked documentation, couldn't figure it out. Please advise, Thank you
[2021-02-03 16:28:34] |
Your setup looks good on our end. Make sure the option for File >> Data/Trade Service Settings >> Common Settings >> Allow Support for Sierra Chart Data Feeds is set to Yes. If you continue to have an issue then we would need to see your Message Log following these instructions: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-02-03 18:53:07] |
You need to subscribe to the NYMEX exchange to get real-time data for CL. You are not currently subscribed to that exchange.
