Date/Time: Mon, 23 Nov 2026 12:28:22 +0000
Settings of MBO
View Count: 3822
[2021-01-18 13:32:33]
User61576 - Posts: 458
pls check the attached screenshot
the MBO is showing all orders above 10 (?)
how do I set it to show only the biggest order?
imageScreenshot_15.png / V - Attached On 2021-01-18 13:32:21 UTC - Size: 13.03 KB - 819 views
[2021-01-20 04:23:23]
Refer to this section:
Market By Order Data: Adjusting Minimum Quantity to Display for Market by Order Data
[2021-01-20 06:24:59]
I followed the instructions in the link
pls check the attached screenshot where you can see the settings are on 50 and I still can see lower amounts. and yes, I disconnected and reconnect
it's the same on other charts I have DOM open
imageScreenshot_16.png / V - Attached On 2021-01-20 06:24:11 UTC - Size: 100.76 KB - 889 views
[2021-01-20 14:27:19]
You need to enable this option (top left of the Symbol Settings window):
Global Symbol Settings: Use Custom Symbol Settings Values (Global Settings >> Symbol Settings)
[2021-01-20 15:31:02]
still not working
another question, is there any way to control the width of the DOM?
imageScreenshot_20.png / V - Attached On 2021-01-20 15:30:32 UTC - Size: 95.26 KB - 666 views
[2021-01-20 17:58:47]
The reason why it is not working is because you are using a Trade and Current Quote Symbol. So that MBO data is for the MES. Update the symbols settings for MES?##_FUT_CME, disconnect and reconnect and you will see the changes.
In order to change the width of the columns in the DOM, refer to the information here:
Global Trade Settings Windows: Chart/Trade DOM Column Widths and Headers (Trade >> Customize Chart/Trade DOM Columns)
[2021-04-22 09:13:20]
User724042 - Posts: 8
HELLO.
I have same issue with mbo.
Cannot displaying the mbo data...
i followed all the step describded above but nothing appear....
[2021-04-22 13:49:23]
WRT Post #7:
Have you gone through the instructions to ensure that you setup your system to get the MBO data? Refer to the instructions here:
Market By Order Data: Step-by-Step Instructions
[2021-06-03 07:46:14]
Yeager - Posts: 136
Hi John,
I didnt have my MBO selected for service package. I have now reset this to renew for level 12 top tier. How can I get MBO turned on now and full book depth? I currently only have top of book with full book on eurex markets only.
[2021-06-04 07:44:43]
You need to activate the exchange fee which includes market depth data. Refer to:
Real-Time Exchange Data Feeds Available From Sierra Chart: Adding Support for CME Market Depth Data
