Date/Time: Sun, 05 May 2024 00:16:07 +0000
Denali and other feed
View Count: 403
[2021-01-12 17:22:04] |
BenjFlame - Posts: 305 |
Hi, I'm currently using Denali feed for CME. Now I'm in need of real time data for stocks in addition. Correct me if I'm wrong, in this case I need to activate Sierra: "Real-Time Data Connections" and the exchanges fees for Nyse/Nasd/amex. is this what I should do? But in this case, won't the "Real-Time Data Connections" take over Denali and serve me your standard non Denali feed for futures? Should I just create completely different account and installation for that Stocks setup? Please advise. |
[2021-01-12 17:42:34] |
Both data feeds can be used. Refer to: Real-Time Exchange Data Feeds Available From Sierra Chart: Using Both Denali Exchange Data Feed and Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
