Date/Time: Fri, 03 May 2024 07:29:06 +0000
Volume by Price causing longer loading time.
View Count: 446
[2021-01-09 01:48:11] |
Shawn J - Posts: 32 |
Hello. When I am trading crypto via Binance, everything is fine until I add Volume by Price to my studies. When I do so, the chart will load for several minutes. I'd like to know what it is about the Volume by Price that is causing the chart to load for a long time. Thank you for your time.
[2021-01-09 02:57:38] |
Refer to: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.23 - Chart Tick Size and Volume at Price Processing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
