Date/Time: Sat, 18 May 2024 19:51:12 +0000
ritmic data
View Count: 416
[2020-12-30 09:17:19] |
User947003 - Posts: 1 |
Hello, I ordered sierrachart with RITMIC datafeed via AMP. I got a password for sierra and I don't have a password for ritmic. I contacted amp suport and they said that sierra does not support ritmic. Why is this package offered? What should I do to do?
[2020-12-30 15:26:53] |
Our recommendation is to use the Sierra Chart Order Routing Service with Data through AMP rather than try to get Rithmic to work. Refer to the following: Sierra Chart / Trading Technologies Futures Order Routing Service You can also choose to use CQG, but again, we recommend the above service, especially since we are no longer subsidizing their historical data. You can read more about this here: Jan 1, 2021 Changes to Historical Data: Interactive Brokers, CQG Just let AMP know which service you want to use and they will get you switched over. If you do use the Sierra Chart Order Routing Service, then you would need to follow the Setup Instructions here: https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#SetupInstructions If you go with CQG, then you would need to follow the Setup Instructions here: CQG Trading Platform Service: Setup Instructions We are no longer supporting Rithmic and we can't say why AMP still is offering the option, they should not be. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
