Date/Time: Wed, 04 Nov 2026 16:19:06 +0000
Switching to Dorman Trading
View Count: 2604
| [2020-12-29 15:17:15] |
| User992529 - Posts: 32 |
Hi Sierra Team, I am planning on switching to Dorman Trading (in-house broker). Any specific things I need to let them know to make this work with Sierra Chart? Regarding fees for order routing for SC can that be included on the FCM side? Best Regards |
| [2020-12-29 16:04:29] |
| John - SC Support - Posts: 48419 |
Just let Dorman know that you will be using Sierra Chart with the Sierra Chart Order Routing service and that you want to have your Order Routing fees paid through your Dorman account. Once you have your account setup with Dorman, then follow these Setup Instructions: https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#SetupInstructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-12-30 08:17:35] |
Regarding order fill billing to your trading account, there is a procedure to handle this and it is documented here: Order Fill Billing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
