Date/Time: Wed, 04 Nov 2026 16:32:02 +0000
not receiving intraday history
View Count: 759
| [2020-12-28 19:30:41] |
| User39675 - Posts: 4 |
Hi...i am not receiving intraday history. only loading todays history. is there something to reset? j telephone [Number removed for privacy] Date Time Of Last Edit: 2020-12-28 22:15:06
| [2020-12-28 20:05:05] |
We are no longer as of December 28, 2020 providing the Sierra Chart provided historical data service for CQG or Interactive Brokers users. For more information, refer to this Support Board thread: Jan 1, 2021 Changes to Historical Data: Interactive Brokers, CQG Also refer to this post: Jan 1, 2021 Changes to Historical Data: Interactive Brokers, CQG | Post: 245144 The solution to this problem is to use the Denali Exchange Data Feed for CME and EUREX data. Step-by-step instructions are here: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* The first calendar month of this data feed is free. Let us know if you need help with the set up and we will help you through all of the steps. In the case of CQG you will then need to contact your broker and cancel CME and EUREX exchange fees through your CQG account so you do not pay exchange fees twice. You definitively do not have to pay any market data exchange fees through your brokerage account to CQG. This is not required. For other exchanges (ICE, HKFE) you need to use the Sierra Chart Exchange Data Feed: Sierra Chart Exchange Data Feed As an alternative to CQG, we recommend using the Sierra Chart Order Routing Service: Sierra Chart / Trading Technologies Futures Order Routing Service In regards to using CQG provided historical data, we definitely do not recommend using that. It has an additional cost of 25 USD per month. The data delivery is slow and inefficient and causes Sierra Chart to freeze during the processing of it. Only 5 days of tick data is supported from CQG. And only current futures contracts are provided. Whereas with Sierra Chart provided data feeds, you will have access to 10+ years of reliable high-speed delivered tick by tick data. Once again we do not advise using CQG historical data and it will not work well with Sierra Chart. And we also provide no technical help or support for any CQG provided historical data or real-time data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-12-28 20:07:03
