Date/Time: Sat, 18 May 2024 20:37:05 +0000
Cumulative Delta Bars - Trades
View Count: 1790
[2020-12-28 16:55:30] |
User847587 - Posts: 18 |
Please describe what is meant by Trades in this indicator. Is this (net) volume by trade?
[2020-12-28 17:45:53] |
User907968 - Posts: 804 |
Cumulative Delta Bars - Trades is the cumulative sum, over the data in the chart or the trading day, of the difference between the number of trades at the Ask price and the number of trades at the Bid price, displayed as High-Low CandleStick bars.
Cumulative Delta Bars - Trades |
[2020-12-28 18:37:57] |
Thank you. My question is what is meant by trade. I'm looking for a definition of trade. I have not seen this term used anywhere else in Sierra Chart literature. Where the term "volume" is used, it is understood that volume means number of contracts (size/qty.) Thanks for your time. |
[2020-12-29 08:37:24] |
This is documented here: Numbers Bars: Definitions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-12-30 07:49:54] |
User90125 - Posts: 715 |
Trades are equivalent to Ticks. A 55 tick chart would be a 55 Trade chart in SC. Refer to this Bar Period Type: Chart Settings: Intraday Chart Bar Period >> Bar Period Type >> Number of Trades Per Bar (Chart >> Chart Settings menu) |
