Date/Time: Sun, 19 May 2024 00:38:01 +0000
Tape column on DOM
View Count: 1188
[2020-12-27 01:19:31] |
User425645 - Posts: 113 |
Hey can you guys code a tape column on the Depth of market? it would be very cool. Thanks |
[2020-12-27 08:52:24] |
We do not understand what is being requested here.
[2020-12-28 00:39:02] |
ok all I meant was, for example, a column on the Dom that showed tape block orders. It would be very beneficial to scalpers to have the tape order blocks so much closer to where we're executing. Moving your eyes from the Dom to the tape take up a surprising amount of very precious time. Trust me, TT and jigsaw both don't have this it would be a game changer for SC. Please let me know if you are in need of more detail
[2020-12-29 19:13:00] |
Have a look at the Market by Order data feature: Market By Order Data This only works with the Denali Exchange Data Feed. There is also the Current Traded Total Volume column which can be added to a Chart/Trade DOM: Global Trade Settings Windows: Customize Chart/Trade DOM Columns (Chart Specific) We could add a volume filter to this column to have it only count trades with a certain volume or higher. Let us know if that would be helpful. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-01-02 06:41:25
