Date/Time: Sun, 05 May 2024 06:08:43 +0000
data is delayed by 5 minutes
View Count: 455
[2020-12-21 16:19:01] |
zzwf - Posts: 17 |
I purchased a data service. But my stock data is delayed by 5 minutes
[2020-12-21 17:47:46] |
John - SC Support - Posts: 31362 |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-12-22 00:26:49] |
How do you come to the conclusion that the data is delayed five minutes?
