Date/Time: Wed, 08 May 2024 22:20:16 +0000
Marking options expiry dates on charts
View Count: 474
[2020-12-02 17:03:53] |
adam czuk - Posts: 26 |
Hello SC support, I would like to create vertical lines on my charts to mark the date of options expirations. Is there a way to do this? |
[2020-12-02 17:21:43] |
John - SC Support - Posts: 31480 |
The easiest way is to use the Vertical Line drawing tool. You can add text to the line as well by using the Modify Text option. Refer to the information here: Chart Drawing Tools: Horizontal Line | Horizontal Ray | Horizonal Line Non-Extended | Vertical Line For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
