Date/Time: Thu, 02 May 2024 01:42:29 +0000
DVP not working
View Count: 430
[2020-11-30 19:10:00] |
User396400 - Posts: 6 |
Hi, I did an update on SC and now when I pull a dvp on the bars it shows up all squashed into that 1 bar. Ive tried different settings but nothing works. Please assist Thank you |
[2020-11-30 19:45:46] |
John - SC Support - Posts: 31293 |
There was a problem from an older release where the Drawn VbP was not updating the number of profiles internally. It's possible that the version you updated from had that issue, but you did not notice it until you updated to the newer version. First, we want you to update to the current version to ensure that you have all the latest changes. Second, remove all the Volume by Price profiles from your chart and then try using the Drawn VbP and see if it works properly for you. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-11-30 22:27:34] |
If you continue to have a problem, run Sierra Chart in Safe Mode: Sierra Chart - Software Login Instructions: Using Safe Mode And the next step is to re-download the data in the chart in case there are any incorrect timestamps: Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart.
