Date/Time: Thu, 02 May 2024 11:31:57 +0000
hallo
View Count: 405
[2020-11-30 16:08:57] |
User893036 - Posts: 1 |
i have an error when i start up my program and becouse of that I can not install a custom study , can you please help me. this is the error: ERROR: missing parameters / HTTP status: Request completed with the HTTP response status code 200 |
[2020-11-30 17:34:44] |
That is insufficient information for us. We need to see the entire Message Log. Instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Also, refer to this page: HTTP Communication Errors Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-11-30 19:24:59] |
John - SC Support - Posts: 31293 |
There was an issue with receiving certain parameters when requesting files, that we have fixed. You should not have a problem downloading the files. Exit and restart Sierra Chart to get any updated files.
For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-12-01 22:43:08
