Date/Time: Sat, 04 May 2024 07:05:01 +0000
Chart drawings text size
View Count: 1533
[2020-11-30 15:50:40] |
grantx - Posts: 244 |
Where do I set the text font and size for drawings? Like horizontal ray, lines etc..
[2020-12-06 13:48:40] |
Sierra - I cannot find where to change the text size for tools. Your help file is not helping. It points to a read only setting. How does one change this? Date Time Of Last Edit: 2020-12-06 13:48:52
[2020-12-06 14:05:17] |
Ackin - Posts: 1865 |
I'm not sure but try: Fonts and Text Graphics Settings: Fonts and Text Appearance |
[2020-12-07 15:20:29] |
John - SC Support - Posts: 31362 |
Refer to the information here: Chart Drawing Tools: Changing the Font Size For Text Displayed with Tool Drawings (Global Chart Drawing Font) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-12-07 15:55:01] |
I have tried that. My setting shows as read only so I am unable to modify it. See attached. |
[2020-12-07 17:15:35] |
Click on where it states [Select Global Chart Drawing Font]. This will bring up the window to select the font. You may need to click it twice, once to activate that section and the second to actually select the button.
