Date/Time: Sat, 27 Apr 2024 12:30:56 +0000
Trading @ Settlement
View Count: 463
[2020-11-30 14:44:11] |
User664240 - Posts: 206 |
Please direct me to these symbols for the Denali order routing? For the Nymex exchange.
[2020-11-30 17:48:15] |
When using the Sierra Chart Order Routing Service you will find these listed in File >> Find Symbol >>Futures-NYMEX. This is an example: CLTF21_FUT_NYMEX More information: Sierra Chart / Trading Technologies Futures Order Routing Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-11-30 18:22:21] |
My apologies I'm using Denali quoting service only.Did you add TAS to to the quote service?
[2020-11-30 18:34:51] |
Message Log says the DOM for TAS is not supported. DO you plan to add them. I would love to move away from CQG execution but SC is not option friendly but I'm looking forward to the time SC takes a more professional view towards options. This is not meant to disparage SC only to state there is plenty of room to grow your platform. I offer as I have in the past to consult with you on how best to improve the facility of option trading on SC.
[2020-12-01 18:58:36] |
We do need to add the TAS symbols to SC Data-All Services. Give us a couple of days for that.
