Date/Time: Sat, 27 Apr 2024 15:06:02 +0000
[Locked] - New Upcoming EUREX Full Order Book Data Feed (Now Available!)
View Count: 16936
[2021-01-11 00:28:10] |
Regarding pricing, for the extended order book feed. It will be reasonable. The exchange fee probably will be about 25 USD per month.
[2021-01-11 13:36:14] |
User98716 - Posts: 10 |
Will there be an exchange fee plus an additional fee for the data feed as indicated here - Sierra Chart Exchange Data Feed
[2021-01-11 16:21:47] |
Yes there is the cost of the Denali Exchange Data Feed as well.: Denali Exchange Data Feed Understand this is an very expensive data feed for us to offer. Initially we we are going to be losing money on it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-01-11 16:41:42] |
BenjFlame - Posts: 305 |
Do you plan to open your feed to other softwares? Might be a way for you to make more $$ out of it.
[2021-01-11 16:47:21] |
That depends on the exchange and whether they allow this.
[2021-01-11 16:58:19] |
Perhaps you could give a breakdown of the total cost involved as it doesn't appear to be straightforward. At the moment the link to the pricing hasn't been updated for the new EUREX feed/exchange. I may or may not have understood it correctly, but if you say the exchange EUREX fee is $25 and we also require the Denali Exchange Data Feed, which is also $25. Then the total cost is $50 to receive the EUREX market depth data feed? Will there be a requirement to have a funded account for a discounted price similar to some of the other nonprofessional exchange options? Date Time Of Last Edit: 2021-01-11 17:08:35
[2021-01-11 22:57:04] |
Yes that is correct in regards to pricing. If you are on the Sierra Chart Order Routing Service the cost of the Denali feed is 20 USD per month: Denali Exchange Data Feed: Pricing There is no requirement for a funded account. The EUREX does not have that concept. Although we may have a new package coming out to support the market by order data which would be a higher cost. As of yet that is not the case though. But you will still get the extended market depth even without this package. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-01-12 10:59:46] |
AndyFiX - Posts: 2 |
Hi, so do you mean I do not need to open an account with, say, AMP Futures in order to get these Eurex data for analysis only? Thank you |
[2021-01-12 15:21:34] |
User450463 - Posts: 113 |
Why can't we just get everything on Denali? I've been very happy with the performance. I'm thinking about getting CBOT data, which means I would have to keep both Denali and SC Data Feed. Is this possible, and will it ever happen if so? While it's not killing me to have both, I trade full time and treat it as a business expense which I would eliminate if possible Thanks |
[2021-01-12 16:45:29] |
Hi, so do you mean I do not need to open an account with, say, AMP Futures in order to get these Eurex data for analysis only? Yes that is absolutely correct.EUREX will be part of the Denali data feed later in January 2021. And when you are using both data feeds, there is a reduced cost: Real-Time Exchange Data Feeds Available From Sierra Chart: Using Both Denali Exchange Data Feed and Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-01-12 17:40:13] |
I pay for Denali through AMP and I pay for SC feed directly to you. Can I get the $10 credit?
[2021-01-13 00:20:11] |
In this case you cannot get the credit. However, it will not matter because we are going to be offering EUREX with the Denali data feed later this month.
[2021-01-20 11:19:16] |
User343060 - Posts: 7 |
Hi, Do you have any news on when this new datafeed will be released ? Thanks, Maxime Date Time Of Last Edit: 2021-01-20 11:19:40
[2021-01-20 13:50:12] |
We do not know still the exact date. The delay is on the Deutsche Boerse side. Update: On our side, regarding all of the hardware and software set up, we expect this all to be done, by Friday. It is the physical connectivity to the exchange which is getting delayed. It should have been done by now. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-01-20 14:07:57
[2021-01-20 15:35:44] |
Looks like the connectivity to the T7 EUREX feeds is going to be done this week. We cannot make a promise, but looks like we can have this out, next week.
[2021-01-21 17:22:39] |
User649641489846 - Posts: 17 |
Will server settings change for SC Futures Order Routing? Based in Germany and trading Eurex and CME. Current settings: Primary Server: Server 3 Backup Server 1: Server 6 Backup Server 2: Server 2 Thanks |
[2021-01-21 19:32:34] |
There are no changes with those settings because that only relates to order routing.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-01-21 19:32:41
[2021-01-22 03:07:03] |
Everything on the Sierra Chart side is now ready to go at this moment for EUREX but we have received information from Deutsche Borse that they will not have the T7 Extended Order Book Interface (EOBI) 10 Gb line ready until February 1. We do apologize for that. However, there will be some days after this, for the data feed to become available because there is additional infrastructure related work which has to be done first. This was ordered back in December. To be ready approximately January 15. And we timed, all the hardware installation in the Frankfurt 2 data center to match up. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-01-28 07:21:02
[2021-01-25 10:35:19] |
To be able to use the new EUREX data feed, requires that you are on version 2223 or higher. This is the Prerelease currently. To update, follow the instructions: Software Download: Fast Update This data feed is not yet released but you need to be on this version or higher as soon as we make it available to be able to use it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-01-25 10:35:33
[2021-01-25 23:36:23] |
User103448 - Posts: 69 |
Is there any release date known? Br |
[2021-01-26 05:17:38] |
Once we get the connection from the EUREX we should be able to get it out the same day. We cannot give any guarantees as to the date because this is not within our control at this point. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-01-26 16:42:59] |
SavantTrader - Posts: 109 |
I'm currently using (and enjoying) your Denali Data + SC Order Routing. Initially (in February), will I need to subscribe to EUREX on my control panel or will it simply become available? I'm looking for EUREX futures, in particular: FGBL (BUND), FESX (STOXX), and FGBM (BOBL). |
[2021-01-27 05:30:47] |
When the EUREX data feed becomes available you will have to activate that particular exchange in order to receive the data .
[2021-01-27 09:31:31] |
ShuvFlowTrader - Posts: 24 |
Hi, I am a demo user now. I am not able to see FDAX intraday delayed movement in chart, its stuck at 9:50 AM 25th Jan, is there any data restriction from Eurex for Demo account ? I have tried opening a new chartbook, and tried reloading & recalculating..but its not moving. The ES & other CME instruments are working fine . Can you pls help ? [Update]- I have reinstalled the latest version from Help menu and after that I could see the intraday delayed chart upto today morning 27th Jan, but the FDAX DOM is not showing the depth , neither the chart is moving. Date Time Of Last Edit: 2021-01-27 09:39:57
[2021-01-27 09:35:11] |
At this time Sierra Chart does not provide streaming Delayed EUREX data but that will be out in February 2021 sometime.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-01-28 07:19:28
[2021-01-27 17:15:36] |
User657945 - Posts: 226 |
Friday is end of month and I do not want to renew the barchart eurex data feed can you confrim that febrauary 1 Eurex from Frankfurt will be running? This was initially suppoose to be by the end of the year then some time in January after the 15th then February 1st but no confirmation at 2 working days from the date. It's really frustrating.
