Date/Time: Sat, 27 Apr 2024 18:37:28 +0000
Blank chart after changing timezone
View Count: 445
[2020-11-29 06:21:34] |
Sargon Petros - Posts: 52 |
Hi, Since using Sierrachart, my Data settings for Denali have been on Singapore time (GMT+8) and I've manually configured each chart to represent Eastern time. When trying to change the timezone of a new chart, for some reason it goes blank and the log file says there's no data to display. I tried changing the timezone of the data feed itself to be Eastern time but the chart then only displays if I manually set it to GMT+8. All my original charts are OK, it's just these new ones for some reason. The only difference is that I'm using the overlay study to show each of the S&P Sector indices. Each of the individual charts went blank too. Please let me know what the steps are to rectify this. |
studies.png / V - Attached On 2020-11-29 06:20:00 UTC - Size: 40.62 KB - 154 views main screen.PNG / V - Attached On 2020-11-29 06:21:02 UTC - Size: 39.23 KB - 155 views |
[2020-11-29 16:59:07] |
Check the Chart Session Times: Chart Session Times They need to be relative to the time zone you are using. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-11-29 17:09:50] |
Thanks - when I check "Use evening/full session" the charts reappear. Essentially I want to see the charts in their native time rather than my local time which is now the case - is this the correct way to do this ?
[2020-11-29 17:13:54] |
Separately, how do I add the label for the main chart as I did in the Subgraph for the overlays?
subgraph.PNG / V - Attached On 2020-11-29 17:13:48 UTC - Size: 38.24 KB - 163 views |
[2020-11-29 19:58:21] |
If the charts are set to Eastern time and you are looking at US cash indices you would use a Start Time of 09:30:00 and an End Time of 15:59:59. Regarding post #4, you need to use another Overlay study and overlay the main price graph of the same chart. You can then select Chart >> Graph Draw Types >> Blank to hide the original chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-11-29 19:58:33
