Date/Time: Sun, 05 May 2024 05:17:37 +0000
DOM ISSUE
View Count: 467
[2020-11-26 10:52:07] |
User700955 - Posts: 2 |
Hi why the price doesn't load in my DOM??? Date Time Of Last Edit: 2020-11-26 19:57:01
ryjr5y5tmu.GIF / V - Attached On 2020-11-26 10:50:56 UTC - Size: 258.25 KB - 191 views |
[2020-11-26 19:55:26] |
This symbols are not correct based upon the Service you have set in Sierra Chart. You need to use the Edit >> Translate Symbol to Current Service command: Edit Menu: Edit >> Translate Symbols To Current Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
