Date/Time: Sun, 05 May 2024 12:42:39 +0000
P&l COMPLETLY WRONG
View Count: 632
[2020-11-24 17:06:36] |
User657945 - Posts: 226 |
I just got a P&L on the chart that is 206points! negative on NQ after a trade where I got as per trade and trade anctivity 9points Symbol Trade Type Entry DateTime Exit DateTime Entry Price Exit Price Trade Quantity Max Open Quantity Max Closed Quantity Profit/Loss (C) Cumulative Profit/Loss (C) FlatToFlat Profit/Loss (C) FlatToFlat Max Open Profit (C) FlatToFlat Max Open Loss (C) Max Open Profit (C) Max Open Loss (C) Entry Efficiency Exit Efficiency Total Efficiency Commission (C) High Price While Open Low Price While Open Note Open Position Quantity Close Position Quantity Duration MNQZ20_FUT_CME (AC130169) Short 2020-11-24 17:49:41.751 BP 2020-11-24 17:51:01.895 12032.25 12029.75 1 3 1 5.00 5.00 5.00 5.00 -5.50 5.00 -5.50 100.0% 100.0% 47.6% 0.00 12035.00 12029.75 2TargetsWithBEStop.twconfig 2 2 00:01:20 MNQZ20_FUT_CME Short 2020-11-24 17:49:41.751 2020-11-24 17:51:01.895 12032.25 12029.75 1 3 2 5.00 10.00 10.00 10.00 -11.00 5.00 -5.50 100.0% 76.2% 23.8% 0.00 12035.00 12029.75 2TargetsWithBEStop.twconfig 2 1 00:01:20 MNQZ20_FUT_CME Short 2020-11-24 17:49:41.787 2020-11-24 17:51:11.514 EP 12032.50 12029.00 1 3 3 7.00 17.00 17.00 F 17.00 -16.00 7.00 -5.00 100.0% 69.7% 21.2% 0.00 12035.00 12029.00 2TargetsWithBEStop.twconfig 3 0 00:01:30 Total: 17.00 Can you please check what's wrong? thx Date Time Of Last Edit: 2020-11-24 17:15:35
[2020-11-24 17:26:14] |
What Profit/Loss value are you referring to? We need specifics. If you are referring to Daily Profit/Loss, then refer to: Help With Daily Profit/Loss Value Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-11-24 17:34:23] |
I refer to the DPL in the Chart
CRAZYP-L.PNG / V - Attached On 2020-11-24 17:33:51 UTC - Size: 4.09 KB - 202 views Attachment Deleted. |
[2020-11-24 17:37:17] |
ok I read it and understood but it's really not nice to close a profit trade and get a scrceen that says that you are loosing 206points on MNQ, if you can do something in the future to avoid it it will good.
[2020-11-24 20:00:46] |
Refer to the documentation we have linked to in post #2. if you can do something in the future to avoid it it will good. We have. Read the documentation. It is quite clear on this subject especially if you are using the Sierra Chart Order Routing Service.
