Date/Time: Tue, 30 Apr 2024 06:47:29 +0000
Times and Sales Font too small
View Count: 1230
[2020-11-23 17:15:31] |
032400mS## - Posts: 8 |
Good Day, I did not find how to change Font in the Times and Sales. Id did both- via Chart and Chart Settings and via Global Settings. Attached you see ScreenShots. Any Ideas? THX for help |
Screenshot at Nov 23 16-59-32.png / V - Attached On 2020-11-23 17:15:12 UTC - Size: 813.23 KB - 295 views Screenshot at Nov 23 16-59-53.png / V - Attached On 2020-11-23 17:15:19 UTC - Size: 844.14 KB - 226 views |
[2020-11-23 19:20:15] |
JohnR - User831573 - Posts: 300 |
Global Settings -> Graphics Settings -> then select Font Tab -> about 13 lines down is "Time and Sales Window" with current font after it. JohnR Date Time Of Last Edit: 2020-11-23 19:20:44
[2020-11-23 20:58:58] |
Update Sierra Chart to the current version: Software Download: Fast Update And refer to the documentation here for changing font sizes: Graphics Settings: Fonts and Text Appearance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-11-24 14:03:19] |
JohnR/quote] John R as postet this is what I did but the sample Font I changed is much bigger than the actual one- I did attach the screenshot to show this.Any Ideas? |
[2020-11-24 14:05:41] |
Sierra Chart Engineering this is exactly what I did, see Screenshots, but it did not help. I updated all Fonts but neither changed the Times and Sales list- see attached Screenshots. Would appreciate an answer that is not standard but that solves my problem. Thank you |
[2020-11-24 16:16:35] |
John - SC Support - Posts: 31189 |
The Time and Sales window is associated with a specific chart. As such, if you have Chart specific graphics settings (i.e. you have gone to Chart >> Graphics Settings - Chart and on that window deselected the option for "Use Global Graphics Settings Instead of These Settings"), then you would need to use that same window to change the font size for the Time and Sales Window. In other words, select Chart >> Graphics Settings - Chart and change the font for the Time and Sales window there. For more information on this, refer to the following: Graphics Settings: Using Different Color and Graphics Settings for Specific Charts For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-11-24 16:39:34] |
Thank you, for whatever reason I thought I did this allready- now it works. Thank you very much.
[2020-11-24 18:43:23] |
Would appreciate an answer that is not standard but that solves my problem. Furthermore, we also instructed you to update to the current version in case there are any issues with the time and sales font setting in the version you are running. You should definitely update in any case as there are many improvements across the program. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-11-24 18:45:17
[2020-11-24 18:53:50] |
Thank you for your effort 🚀🚀
