Date/Time: Fri, 03 May 2024 17:59:09 +0000
Trend line drawings wrongly copied in tick charts
View Count: 622
[2020-11-20 11:35:58] |
User350416 - Posts: 43 |
Hi, I'm using 5min, 1 min, 3 tics and 1 tics range charts. In the tick charts I copy the drawings from the min charts by using Chart settings > Advanced settings 2> Copy chart drawings from chart # The horizontal levels are copied correctly but not the trend lines which display wrong levels In the attached picture you can clearly see the current price is at 3539.00. In the min chart the price is touching the bottom trend line and this trend line remains below the 3541.75 resistance level However, in the 1 tic range chart the trend line is not copied at the same location but well above: - the current price is not touching the trend line and - the trend line crosses above the resistance level ... which is completely wrong. The 3 tic range chart shows exactly the same wrong levels. Can you please fix this? Thank you |
[2020-11-20 11:38:38] |
Example 2
Attachment Deleted. another example.png / V - Attached On 2020-11-20 11:38:33 UTC - Size: 273.56 KB - 195 views |
[2020-11-23 18:01:49] |
Can somebody reply? thank you
[2020-11-25 15:12:16] |
Refer to: Lines/Rays or Other Chart Drawings Move After Drawing Them We cannot provide further help other than this documentation. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-11-25 15:12:23
[2020-11-27 08:54:47] |
The doc is very clear and helpful, many thanks
