Date/Time: Sun, 19 May 2024 15:52:42 +0000
Sierra Update: 2191 (October 31, 2020)
View Count: 463
[2020-11-02 15:12:45] |
User991052 - Posts: 30 |
Support, Q. Are your " settings windows " meant to be presenting like this?? Please see screenshots. Note: Change has ONLY come about since last update. Regards, |
Screen Shot 2020-10-31 at 16.46.37 (5).jpg / V - Attached On 2020-11-02 15:11:16 UTC - Size: 302.43 KB - 186 views Screen Shot 2020-11-03 at 02.03.06 (2).jpg / V - Attached On 2020-11-02 15:11:30 UTC - Size: 152.15 KB - 179 views |
[2020-11-02 15:18:30] |
John - SC Support - Posts: 31733 |
Yes, those are beginnings of the new windows that we are working on in order to remove the dependency on Windows. You will a bit of information on this in this thread: What is Sierra Chart Working On For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
