Date/Time: Mon, 20 May 2024 01:27:29 +0000
Left Side Scale being cropped on low $ stocks
View Count: 566
[2020-10-27 05:36:56] |
gjockey - Posts: 47 |
Hi, this issue might be similar to an issue I brought up earlier. Left side scale numbers getting cut off. Can I add padding? I want to enable left side scale to display volume on the left scale and price on the right scale. For illustration, I created a simple chart with ONLY the volume study added and left side scale enabled. The issue appears to be that the "room" on the left side scale is dictated by the room on the right hand scale. When the stock is inexpensive and contains only 3 digits in the price on the right scale, that 3 digits of space is used on the left side scale and results in cropping if the left scale number is larger than 3 digit space. GE left side scale volume is cropped while a more expensive ticker like "SPY" is not. (see attachemnt) Date Time Of Last Edit: 2020-10-27 05:39:00
Sierra1.jpg / V - Attached On 2020-10-27 05:36:48 UTC - Size: 108.93 KB - 235 views |
[2020-10-27 06:40:50] |
We will look this over and implement a solution.
[2020-10-28 09:57:49] |
User90125 - Posts: 715 |
Have also noticed the opposite effect viz. the Left Hand Scale adding unnecessary padding when the Chart DOM is enabled in its default position on the right side of the chart. Might be worth looking into as well, since it's easily reproduced, and involves the Left Hand Scale. Thanks. |
[2020-10-28 20:06:29] |
Provide an image of the chart or Trade DOM, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-10-29 22:40:24] |
Before: http://www.sierrachart.com/image.php?Image=1604000924587.png After Chart DOM added: http://www.sierrachart.com/image.php?Image=1604001105224.png |
[2020-10-30 19:09:01] |
Update to the very latest version and see if you still notice this. We do not observe this in the current version. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
