Date/Time: Wed, 29 May 2024 06:20:31 +0000
Number bars issue with Nse india datafeed (global datafeeds)
View Count: 468
[2020-10-27 04:48:43] |
User529177 - Posts: 2 |
not getting correct number bars display kindly check and guide Ask & bid numbers are repeating .
of ril nse.jpg / V - Attached On 2020-10-27 04:47:40 UTC - Size: 172.07 KB - 185 views chart setting.jpg / V - Attached On 2020-10-27 04:48:01 UTC - Size: 120.94 KB - 191 views data loaded.jpg / V - Attached On 2020-10-27 04:48:12 UTC - Size: 37.64 KB - 170 views |
[2020-10-30 18:53:55] |
What bars are you specifically referring to in that chart? The Numbers Bars with zeros would indicate historical data downloaded from this service. That data does not have the necessary data for Numbers Bars. Also, set Sierra Chart to a Tick by Tick Data Configuration. Follow the instructions here to do this: Tick by Tick Data Configuration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-10-30 18:54:16
[2020-10-31 00:56:19] |
I am referring to all 3 bars which have data . The ask and bid are repeating . It seems there data is faulty .
[2020-10-31 14:28:24] |
Not sure where you are seeing the repeating data although if you have any questions about the data providers data, you need to ask them.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-10-31 14:28:35
