Date/Time: Mon, 29 Apr 2024 14:26:36 +0000
Cumulative TICK
View Count: 1340
[2020-10-17 18:56:22] |
User575399 - Posts: 305 |
I am using $TICK and I want my cumulative TICK study to resemble the photo attached(with grey background) but my chart(black background ) doesnt look anything like it. How can I fix this? Thanks!
Screenshot (203)_LI.jpg / V - Attached On 2020-10-17 18:56:02 UTC - Size: 784.67 KB - 661 views Screenshot (202)_LI.jpg / V - Attached On 2020-10-17 18:56:14 UTC - Size: 2.17 MB - 492 views |
[2020-10-18 10:48:45] |
Try setting the Reset at Start of Trading Day Input to Yes: Cumulative Sum of Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-10-18 14:08:41] |
That will give me the bars and zero point like the grey graph? I don’t think you really looked at the pics. Instead of the line that I get, I want the bars in the other pic with the grey background . How do I get that ? Date Time Of Last Edit: 2020-10-18 14:09:21
[2020-10-19 14:42:01] |
Change the Subgraph Draw Style to Bar. Refer to the information here: Chart Studies: Bar (ACSIL: DRAWSTYLE_BAR) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-10-19 23:03:08] |
Still not working . It doesn’t have a zero axis .Any other ideas ?
[2020-10-20 00:22:00] |
Ackin - Posts: 1865 |
You will have a zero axis when restarting a new day. This is already written above. See the attachment: |
tick cum.png / V - Attached On 2020-10-20 00:21:53 UTC - Size: 136.51 KB - 1231 views |
