Date/Time: Wed, 15 May 2024 00:19:42 +0000
My volume profile Based on Tpo's width does not increment
View Count: 485
[2020-10-08 21:16:43] |
User563984 - Posts: 17 |
Hello, I have problems in making my Vol profile Based on TPO to plot wider. It's narrower than the numbers. I have attache a screenshot. Thank you! matteo |
Attachment Deleted. Vol prof width.png / V - Attached On 2020-10-08 21:16:09 UTC - Size: 189.61 KB - 162 views |
[2020-10-09 13:56:49] |
John - SC Support - Posts: 31627 |
One of the things to check is if the option for Volume Profile Bars Length Relative to All Visible Profiles is set to Yes, as this can cause the bars to be smaller, depending on the values of other visible bars. Refer to the information here: Volume By Price Study: Volume Profile Bars Length Relative to All Visible Profiles Otherwise, the only way to control the width is to change the chart spacing. Refer to the information here: Working With Charts: Changing Bar Spacing For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
