Date/Time: Sat, 21 Nov 2026 11:03:41 +0000
scrolling charts faster way? zoom tool for section of chart?
View Count: 4467
[2020-09-26 12:28:11]
HeyUgly - Posts: 290
using seirra for awhile, but dont know why i cant find this feature
scrolling a larger charts with mouse is slow, very slow if going multiple days etc, is there any way to add a scroll slider on the bottom of charts?
also, is there not a tool to highlight a certain area of a chart and have it zoom in? this seems like a pretty basic chart function of majority of platforms, i cannot find it on sierra
thanks in advance
[2020-09-26 12:39:01]
Ackin - Posts: 1866
"This is accomplished by changing the Global Settings >> General Settings >> General 2 >> Scroll Multiplier. The default is 1.0. Use a smaller value to scroll by a smaller amount. Use a larger value to scroll by a larger amount."
Working With Charts: Scrolling The Chart and Right Side Fill Space
Date Time Of Last Edit: 2020-09-26 12:48:31
[2020-09-26 12:44:26]
Ackin - Posts: 1866
menu >> Chart >> Show Scrollbar
[2020-09-28 16:24:54]
As noted above, there is a scrollbar on the bottom of a chart, but it can be turned off. Make sure the option is selected on. Documentation:
Chart Menu: Show Scrollbar (Chart menu)
As to the Zoom In capability, it is located under the Tools menu (Tools >> Zoom In). Refer to the documentation for it here:
Working With Charts: Zooming In and Out
Date Time Of Last Edit: 2020-09-28 20:14:26
