Date/Time: Sun, 28 Apr 2024 00:32:55 +0000
50day moving average
View Count: 583
[2020-09-24 03:26:50] |
User575399 - Posts: 305 |
Hello, I’d like to put the 50 day simple moving Average on my intraday pnf chart. When I add the study it doesn’t match my other daily chart. Not sure if a setting is incorrect . Any ideas? Thanks
[2020-09-24 03:47:26] |
Are there 50 days of data loaded in the Intraday chart?
[2020-09-24 10:33:41] |
Yes. 90 to be exact.
[2020-09-25 03:22:26] |
Really to accomplish what you want accurately you need to use the Study/Price Overlay study: Study/Price Overlay Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
