Date/Time: Thu, 02 May 2024 21:00:55 +0000
SC Charts
View Count: 466
[2020-09-23 02:39:22] |
User22591 - Posts: 133 |
We have be having a frequency of "Sierra Chart stop working" Error; A problem caused the program to stop work correctly. This has been happening for quite sometime and at times at critical time. What could be the problem? Winston Peak |
[2020-09-23 04:08:17] |
We want you to update to the current version of Sierra Chart: Software Download: Fast Update And then run Sierra Chart in Safe Mode: Sierra Chart - Software Login Instructions: Using Safe Mode Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
