Date/Time: Sat, 04 May 2024 19:44:03 +0000
DIFFERENCE IN CANDLE FORMATION IN SIERRA CHART
View Count: 473
[2020-09-22 03:34:45] |
AC135388 - Posts: 2 |
GOODNIGHT. I HAVE A QUESTION REGARDING THE TIMING OF THE SIERRA CHART PLATFORM. I WAS COMPARING THE SAILS OF SIERRA CHART IN 2 MINUTES, WITH THE PLATFORMS NINJA TRADER AND ATAS, NINJA TRADER AND ATAS HANDLES THE SAME MOVEMENT AND THE SAME SHAPE OF THE SAIL IN TWO MINUTES, WHILE IN SIERRA CHART DOES NOT, REVIEW ALSO TIMES AND ON THE THREE PLATFORMS ARE THE SAME, WHICH MEANS THAT THE ERROR IS ONLY IN TWO-MINUTE CANDLES. ATTACHMENT I SEND IMAGES AT THE SAME TIME IN REAL TIME. I ALREADY HAVE THE LAST INSTALLATION OF SIERRA CHART 2171, I WOULD LIKE TO KNOW WHAT THIS DIFFERENCE IS DUE TO AND IF IT HAS ANY SOLUTION. I THANK YOU VERY MUCH FOR YOUR COLLABORATION AND I LOOK AT YOUR RESPONSE. THANK YOU. JOHANNA MARTIN |
Private File Private File Attachment Deleted. |
[2020-09-22 10:44:22] |
When posting an image of a chart only use the method here: https://www.sierrachart.com/index.php?page=PostingInformation.php#PostingAnImage We want you to refer to this section about bar starting times which may be relevant: Chart Session Times: Bar Starting Times Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
