Date/Time: Sun, 28 Apr 2024 21:21:20 +0000
weekend data and session times
View Count: 764
[2020-09-21 05:56:23] |
User884550 - Posts: 149 |
is it possible to get rid of this weekend session split as attached, so that weekend action until monday session start would be merged with Friday?
Bund session weekend.jpg / V - Attached On 2020-09-21 05:55:52 UTC - Size: 277.81 KB - 190 views |
[2020-09-21 21:30:06] |
There is not a way to do what you are asking for. You can choose to not load the Weekend Data, but that will just eliminate the data and not associate it with Friday. Refer to the information here: Chart Session Times: Load Weekend Data Setting (Chart >> Chart Settings >> Session Times) Any other change will affect all the days, not just the weekend data, such as changing your Session Times to limit to the Regular Trading Hours. Refer to the information here: Chart Session Times Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-09-23 06:48:49] |
it seems I also have same unrelevant vertical grids during the week, ass screenshot
Bund session.jpg / V - Attached On 2020-09-23 06:48:45 UTC - Size: 239.93 KB - 182 views |
[2020-09-23 08:07:39] |
This will be resolved in the next release.
[2020-09-24 05:57:02] |
in latest 2174 this thing seems to be completely off, attached
Es session.jpg / V - Attached On 2020-09-24 05:56:53 UTC - Size: 289.97 KB - 189 views Bund session.jpg / V - Attached On 2020-09-24 05:56:57 UTC - Size: 276.38 KB - 192 views |
[2020-09-24 06:01:29] |
Sierra_Chart Engineering - Posts: 14124 |
Attach one of those charts by following these instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-09-24 06:08:30] |
attached
sessions for Sierra.Cht - Attached On 2020-09-24 06:08:22 UTC - Size: 3.9 KB - 239 views |
[2020-09-24 14:08:30] |
User90125 - Posts: 715 |
Same thing for me last night. v2174 64-bit (33352:33353). Pretty much unusable, as shown. http://www.sierrachart.com/image.php?Image=1600956284881.png |
[2020-09-24 22:35:39] |
Issue still occurring in v2174. Happens when under Chart Settings >> Advanced Settings 2, enable Vertical Grid Lines and select "Session Start". Anything that users can do to get a working, usable chart with proper Session Start lines going forward would be helpful. Thanks. |
[2020-09-24 23:59:30] |
We have resolved the remaining issue. This will be out in version 2175 coming out later this evening.
[2020-09-25 06:20:43] |
looks fine now
