Date/Time: Tue, 30 Apr 2024 13:45:19 +0000
Nrs Bars
View Count: 392
[2020-09-20 16:07:59] |
User736044 - Posts: 51 |
In Nrs bars settings under Determine Max/Min Values for Coloring from: daily data or bar data, it seems to me like there is no change and looks like it shows by daily data even if I switch to bar data
[2020-09-21 15:18:42] |
John - SC Support - Posts: 31194 |
Be aware that only some of the Background/Text Coloring options are affected by the change in that setting. Refer to the list of these here: Numbers Bars: Determine Maximum/Minimum Values for Coloring From If you are using one of the affected coloring types, then please attach a couple of screenshots showing us what you are seeing in both cases. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
