Date/Time: Fri, 03 May 2024 11:51:02 +0000
Is it possible to set up the DOM to better show dynamic orderflow changes more like JS?
View Count: 611
[2020-09-18 20:03:22] |
User886650 - Posts: 3 |
Completely new to SC and just getting it set up, hopefully to move to it as a full time solution away from NT. I posed this question via email but was directed to post it here - After installing the trial I am lost as to how and create a more jigsaw like dom from what I am currently seeing. I'm wondering if this is even possible or if there is something more needed from the version/package provided with the trial? Can any of you provide instructions for this or share a setup? I am planning to recreate my charts this weekend to use in testing next week but this DOM configuration has me stumped. Thanks. |
[2020-09-20 02:12:00] |
First, make sure you are using the Delayed Exchange Data Feed: Delayed Exchange Data Feed And then there are various market data columns you can add to the Trading DOM: Global Trade Settings Windows: Customize Chart/Trade DOM Columns (Chart Specific) And refer to the descriptions here: Global Trade Settings Windows: Chart/Trade DOM Column Descriptions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-09-20 02:12:26
