Date/Time: Sat, 04 May 2024 08:59:30 +0000
Additional option in General Settings
View Count: 661
[2020-09-17 15:30:45] |
nicktrader - Posts: 665 |
Is it possible to add the additional option "Do not save drawings" in General Settings (2)? With my QuoteBoard I manage different symbols and insert drawings in different TF for each symbol. I have activated the option "Display Save ...on Exit" and I want to keep it that way. To delete now all drawings for each symbol (and TFs) from the previous day is very complex. Therefore the question above if you can integrate this option. Many thanks |
[2020-09-17 16:18:08] |
John - SC Support - Posts: 31362 |
We doubt we would be able to get this kind of a change any time soon. But there are two options to quickly delete drawings from a chart under the Tools menu: Erase All Text, and Erase All Non-Text Drawings. Refer to the information for these options and others in this section: Chart Drawing Tools: Erasing Chart Drawings For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-09-18 03:06:07] |
Thanks John, of course I know these commands and they are part of the shortcut menu. However, it is still extensive. For each symbol I draw in three different TFs and I observe more than five different symbols. In total 15 times. In addition to that, each time a confirmation has to be done. Is it possible to switch off the confirmation window? |
[2020-09-18 13:21:31] |
There is no way to turn off the confirmation window to delete the drawings.
