Date/Time: Mon, 29 Apr 2024 06:04:54 +0000
FIB levels
View Count: 444
[2020-09-17 15:18:17] |
User630140 - Posts: 5 |
hi I like to know if it's possible to set up FIB levels ,that's mean for example is the Market's retraced 38% ,then automatically printed A-8%line from the previous High to the low where it's 38%
[2020-09-17 16:00:20] |
You can use the drawing tools for Retracement/Projection. Refer to the information here: Chart Drawing Tools: Price Retracement (2 point) | Price Expansion (2 point) | Price Projection (3 point) Tools You can also see if the Auto Retracement/Projection study can do what you want: Auto Retracement/Projection For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
