Date/Time: Wed, 01 May 2024 02:56:27 +0000
Can't get back adjust to work
View Count: 490
[2020-09-17 01:51:12] |
User148596 - Posts: 214 |
Hi, I have followed the steps for getting the back adjusted data but it isn't working (Chart Settings>Advanced Settings>Volume Based Rollover Back Adjusted). All the charts in my chartbook read [CBC][M] Symbol Settings shows Rollover Method as Default (8 Calendar Days etc.) Thanks for your help :) |
[2020-09-18 09:52:42] |
We need to know exactly the specific issue you are seeing and how you are determining that. The first step is to re-download the historical daily data files for all contract months for the chart: Continuous Futures Contract Charts: Re-Downloading Continuous Futures Contract Data There is an option for this on the selection window for the individual contract months. And then also refer to: Continuous Futures Contract Charts: Controlling Rollover Amount for Back Adjustments Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-09-18 09:53:36
[2020-09-18 16:03:46] |
Thank you, this is in fact a sub instance. I noticed in the literature that may affect things? Do I need to perform the proper rollover adjustments in the original instance of SC in order for this to work properly? The issue as I see it is that in ES the recent all time high is about 3579 on 9/01 and 9/02 when it should be 3587. Thanks |
[2020-09-18 19:03:54] |
Do I need to perform the proper rollover adjustments in the original instance of SC in order for this to work properly? It depends upon how this setting is set:Global Symbol Settings: Use These Symbol Settings in New Instances When Started (Global Settings >> Symbol Settings) The reason for this is because you are back adjusting the data: The issue as I see it is that in ES the recent all time high is about 3579 on 9/01 and 9/02 when it should be 3587.
Do not use one of the back adjusted continuous futures contract options. You must not use that if you want to see the true prices.
