Date/Time: Sun, 05 May 2024 06:38:57 +0000
Live bracket limit order gets filled as market order on LIVE but SIM works fine
View Count: 369
[2020-09-16 03:19:08] |
User118473 - Posts: 16 |
hi, when switch to live from SIM the limit bracket order gets filled as live order as a result lost money just now. For some reason SIM limit bracket order works fine but when change to LIVE limit bracket order gets filled as Market order although the Target on DOM is same as SIM. Please send email address where i can send over video and screenshots. 1 video and 2 screenshots files attached,Thank you.
screenshot of DOM setting.png / V - Attached On 2020-09-16 03:15:44 UTC - Size: 417.01 KB - 155 views Private File live braket order traget get set up image.jpg / V - Attached On 2020-09-16 03:17:25 UTC - Size: 530.8 KB - 176 views |
[2020-09-16 10:29:29] |
We know what the problem is. You are receiving delayed data. Your broker did not complete the setup of the data feed by activating the necessary exchanges. They need to do this here: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation&UserID=202703#DenaliExchangeDataFeed Also you are running an older version of Sierra Chart. It is important to update now following these instructions: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-09-16 10:30:19
