Date/Time: Tue, 07 May 2024 03:43:19 +0000
Depth data is showing fine on the DOM, but NOT my charts. (moving to Denali from SCEDF)
View Count: 434
[2020-09-16 01:19:48] |
User510771 - Posts: 3 |
The depth data is showing fine on the DOM. Just not my charts. My footprint chart should have numbers bars showing the buys and sells. All I have is a blank chart with the correct price showing on the right edge. Same with the heat map chart. I may want to just go back to the feed I was using if I can't get this data to show up on my charts.
[2020-09-16 10:31:34] |
First thing to do is to update Sierra Chart to the current version: Software Download: Fast Update And then use this command on the Edit menu to translate the symbols to the current service: Edit Menu: Edit >> Translate Symbols To Current Service If you still need help provide an image of the chart. Provide an image of the chart or Trade DOM, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-09-16 10:32:06
[2020-09-16 16:37:55] |
I figured out my problem. Somehow when I was switching over to Denali I inadvertently change my service package from the advanced package to the standard package, which does not support numbers bars. Once I realized this, I switched backto the advanced package and my charts returned to normal. Thanks for your help with my self-imposed problem. |
