Date/Time: Thu, 02 May 2024 02:59:39 +0000
Status Bar in SC v2168
View Count: 609
[2020-09-15 21:00:49] |
Botan626 - Posts: 294 |
Thank you SC team for taking care of this issue Information does not fit into Status Bar. But is it possible to make status bar's width auto variable (based on the width of text trying to fit inside) or manually editible? See this screenshot please: http://www.sierrachart.com/image.php?Image=1600202860313.png , status bar is excessively wide and if I try to add a new button to control bar it adds arrows, which can be avoided by making status bar narrower. Date Time Of Last Edit: 2020-09-15 21:01:13
[2020-09-16 14:45:50] |
John - SC Support - Posts: 31293 |
Refer to this setting: General Settings Window: Status Bar Width in Characters (Global Settings >> General Settings >> GUI >> Application GUI) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-09-16 16:57:02] |
Thank you, John. I believe this info you gave me link to would be helpful if mentioned on this page too: Status Bar I actually checked that page after I updated to v2168, but no new info was added there. |
[2020-09-16 18:28:57] |
Thank you, we have added a reference to that setting on the Status Bar page as well.
