Date/Time: Sat, 27 Apr 2024 18:24:38 +0000
March 2021 contracts
View Count: 504
[2020-09-14 12:10:14] |
User111602 - Posts: 17 |
Hi, I have a problem with downloading data for F.US.EPH21 contract (and more index future for that matter too). It shows up on my symbol list but when I try to open intraday chart with it gives me error like no such instrument for download. I already contacted cqg but they say the symbol is ok on their side. Cant figure out whats up with it. Could you please help solve this issue? Thank you.
[2020-09-14 16:12:55] |
Attach your Message Log per these instructions: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-09-14 16:43:12] |
I have just sent log for analysis through "Send to Analysis" on my message log.
[2020-09-14 18:27:00] |
Data is not maintained for that symbol yet for CQG but we will add support for that.
[2020-09-14 18:58:23] |
Thank you very much, can I ask when aprox. its going to be added?
