Date/Time: Sun, 05 May 2024 21:13:01 +0000
Chart not showing data
View Count: 416
[2020-09-11 19:07:18] |
dd45 - Posts: 41 |
can you tell me which data I need to purchase to get real time ES futures data. Also which data for real time data on the etf SPY. thank you! sorry this all is confusing for me
[2020-09-11 21:02:59] |
John - SC Support - Posts: 31379 |
If you want to get this data from us (Sierra Chart), then you would need to use the Denali Exchange Data Feed with an appropriate exchange for the CME Group of data for the ES, and you would need to use the Sierra Chart Exchange Data Feed with the U.S. Equities exchange for the SPY. Refer to the following page for general information, which also links to both of the data feeds: Real-Time Exchange Data Feeds Available From Sierra Chart Also refer to this specific section about using both of the data feeds: Real-Time Exchange Data Feeds Available From Sierra Chart: Using Both Denali Exchange Data Feed and Sierra Chart Exchange Data Feed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
