Date/Time: Sat, 04 May 2024 10:09:48 +0000
Hide Region
View Count: 725
[2020-09-10 12:42:48] |
User969241 - Posts: 72 |
I tried to hide certain regions by advanced settings 2 > region > state but the regions won't go away and the studies remain showing in them?
[2020-09-10 14:58:14] |
John - SC Support - Posts: 31362 |
The setting you are referring to is just for the Region Data Line, which is the informational data line at the top of each region. Refer to the information here: Chart Settings: Region Data Lines (List) (Chart >> Chart Settings >> Regions >> Region Data Line menu) The only way to remove a region is to either hide or remove all the studies that are in that region. Refer to the following information: Chart Studies: Settings and Inputs Tab >> Chart Region For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
