Date/Time: Mon, 29 Apr 2024 13:05:11 +0000
Market Depth SC data / IB Trading + SC Data
View Count: 542
[2020-09-08 12:50:42] |
Torsten Grüß - Posts: 45 |
I have a question if I select SC data as data connection I get a market depth of over 10 levels in the " Future ESU20 ". But then I use my data connection IB Brocker for trading and SC for the data. Do I only get a market depth of 1 level Is it possible to set up the service Interactive Brokers [trading] so that I can see all levels ? Thanks a lot |
Screenshot_66.png / V - Attached On 2020-09-08 12:21:45 UTC - Size: 135.74 KB - 194 views Screenshot_65.png / V - Attached On 2020-09-08 12:21:51 UTC - Size: 147.05 KB - 187 views |
[2020-09-08 19:59:39] |
For the full market depth data for CME futures when using Interactive Brokers you need to use the Denali Exchange Data Feed: Denali Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-09-08 20:00:00
