Date/Time: Sun, 19 May 2024 10:21:36 +0000
[User Discussion] - Angle based on gradient color choice, default or selectable?
View Count: 662
[2020-08-25 14:25:43] |
User164231 - Posts: 278 |
So when using High Low for time period, I chose Angle based on gradient, I get two choices of colors. Despite choosing a darker color what I get is always a lighter shade. Is there a work around? Thanks. Date Time Of Last Edit: 2020-08-25 14:27:13
Angle based gradient color choice.jpg / V - Attached On 2020-08-25 14:24:46 UTC - Size: 167.55 KB - 220 views |
[2020-08-26 00:45:39] |
To begin with, you should not be using the Auto-Coloring options for that study. Those are for studies that have a line that varies and then allows coloring based on that variation. In this case, you are just dealing with a straight line, so that should be set to None. Then just set the color as you want it to be for that item using the one color option. Refer to the information here on Auto-Coloring: Chart Studies: Subgraphs Tab >> Auto Coloring And refer to the information here on the color settings: Chart Studies: Subgraphs Tab >> Color Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-08-26 04:11:23] |
1. How can I have 2 tone visual aid on stair steps whenever there is a new high or low? 2. Just out of curiosity, when angle based gradient is selected, what is the purpose of the 2 color tabs circled on jpeg if they do not represent the colors of stair steps on chart? |
Angle based gradient color choice.jpg / V - Attached On 2020-08-26 04:10:32 UTC - Size: 80.65 KB - 218 views |
